can anyone tell me what this is on the fuel pump? I have been told i may need to replace it. I was told it was the fuel stop solonoid. Any clues? Or anyone have one?
sorry me again
Yes according to toyota that is the fuel stop solonoid but they dont list it on there parts file. They told me that they cant supplie it there is no part number for it.Originally posted by tigerbuc2004can anyone tell me what this is on the fuel pump? I have been told i may need to replace it. I was told it was the fuel stop solonoid. Any clues? Or anyone have one?
What is wrong with it ?
apparently the garage say they cant feel it working and reckon its sometimes not allowing fuel on start up so engine turns over but wont fireOriginally posted by brian gilliesYes according to toyota that is the fuel stop solonoid but they dont list it on there parts file. They told me that they cant supplie it there is no part number for it.
Not sure why Toyota don't have a part no. for this as it's a standard part on most diesel fuel pumps and even on older fixed jet petrol carburettors. My daughter's diesel fiesta had a problem with the solenoid sticking so not allowing the engine to stop, as it's the solenoid which blocks the flow of fuel to the injectors, thus allowing the engine to cease to fire.
Might just need to be removed, cleaned, tested and put back. I believe you can test them by putting a voltage across the contacts and earthing the body, which should make the rod/plunger/valve tap in the body move out to block the fuel inlet pipe. Carb cleaner should do the trick if it is just dirty.Mike G
it looks a git to get off not sure what to do!!!!!Originally posted by TallymanNot sure why Toyota don't have a part no. for this as it's a standard part on most diesel fuel pumps and even on older fixed jet petrol carburettors. My daughter's diesel fiesta had a problem with the solenoid sticking so not allowing the engine to stop, as it's the solenoid which blocks the flow of fuel to the injectors, thus allowing the engine to cease to fire.
Originally posted by tigerbuc2004any help? no-one have a spare or a complete pump?
give this guy a ring he's called Mike i just got a leccy ariel off him from ebay seems ok and has another breaker in this week tel no.01287 640397
or try this no.07977 975112 its streetluge chris from herehttps://www.facebook.com/groups/henpals/
cheers mate have tried him and he is going to keep an eye out for one.Originally posted by stormforce1067give this guy a ring he's called Mike i just got a leccy ariel off him from ebay seems ok and has another breaker in this week tel no.01287 640397
out of interest does anyone know if the solonoid/pump may be the same on another vehicle?
Fuel stop solonoid
Just picked mine up today gonna fit 2moz (ECD SPILL CONTROL VALVE) OR Fuel Stop Solonoid as its normally called. You can buy these at Merlin Diesel Systems LTD 01772694130 ask for steve £88.13 inc vat.
These pics are of the Denso part number which was a pain in the arse to get hope this can help out.(www.merlindiesel.com)
Andy
Ps they are different on the 3ltr to the 2.4ltrLast edited by a_hartley304; 17 October 2005, 19:07.
cheers will try them, much appreciatedOriginally posted by a_hartley304Just picked mine up today gonna fit 2moz (ECD SPILL CONTROL VALVE) OR Fuel Stop Solonoid as its normally called. You can buy these at Merlin Diesel Systems LTD 01772694130 ask for steve £88.13 inc vat.
Andy
Toyota don't list any parts for the fuel pump, just the whole pump. 'You can't take it apart' said the parts guy last time, (I had one in bits in front of while on the phone!!Originally posted by TallymanNot sure why Toyota don't have a part no. for this as it's a standard part on most diesel fuel pumps
) I think a deisel specialist will be more helpfull than the main dealer, its just a standard Denso unit, and they probably get parts direct from them.
