I have a 2.4 turbo 1990 G reg surf and I am experiencing some heating problems which are that when I go
for a longish drive the water goes to expansion water bottle and fills it up, if I then put back the water from the expansion
tank into main rad filler then there seems to be the right amount that i started with...for some reason it doesn't suck it up from the expansion tank
I have replaced the hose in expansion tank and it still does it, I have had the head tested for head gasket leak but was told it was ok
I also had the radiator check cleaned and tested this is ok too..am I missing something can anyone shed some light on what this problem might be and can I fix it?
thanks Shiny
thanks Shiny
