what sump plug washer?
  • what sump plug washer?
    Just before I get stuck with the oil out and no new sump plug washer to put it back together, do I need a special washer or will a certain size of the normal copper washer do the trick?
    thanks
    James
    Milners do fibre washers at 50P each. I've changed oil twice before and re-used the old washer without any problems, although I've bought a couple this time with three oil filters (saves on postage). As long as they are tight and not leaking you could probably get away with re-using the old one but it's your decision.
    Mike G
      What Sump Plug Washer?
      The latest magazine from the "Which?" group, dedicated to in-depth surveys of sump plug washers, and rooting out the purveyors of inferior oil-sealing products
      Available on subscription, sign up now to get your first 59 issues free, and the 60 bonus issue at only £36,754.99, plus an EXCLUSIVE free gift of our number 1-rated sump plug washer.
      Peter
      I am not a number. I am a FREE MAN!
        thanks Tallyman - I'll try Milners.
        CaptainBeaky appears to have flipped, so I'll back away quietly before anything else happens....
