Hi!
Yet more problems with my Surf. Recently had a new head fitted. Seems ok since been done, but the problem I've got at the moment is oil contamination in the water expansion bottle and around the radiator cap. Thought it was possibly a problem to do with the new head. When I called my mechanic, he was baffled as to why there was oil in expansion bottle, and the engine oil level was normal, he checked the engine, said that was running ok, didn't seem to be a problem with the new head.Then he checked the transmission oil and that was low, well I had not long topped up the transmission oil myself as it was very low, so he's saying it's transmission oil in the water which means a problem with the radiator and the pipes that cool the transmission box. He's saying that I will probably need a new radiator, but I was wondering if there was anything else we can do, before I go paying out for a new rad. Would a radiator flush help at all? I'd read that the oil could possibly be left from the earlier problem with the cracked head? Any ideas / suggestions of what I can do?
Thanks,
Thanks,
