ok i know ive looked at the search function and seen this asked before i can close my window with the ley but not open it and it works fine from inside the truck im guessing its a relay bust somewhere it was suggested that the key microswitch may be duff where is this lol and how do i change it ? Must admit found this site really really helpful thaanks very much for the advice chris
rear window
Ok thought it was just a switch in the key barrel that needs changing or was i mistakenOriginally posted by BUSHWHACKER
Check the continuity across the switch before deciding it is at fault . I thought my rear key switch was faulty but it was a corroded pair of wires where the tailgate hinges . Window worked fine by switch inside but would not go up or down by key switch . As yours does work one way I would suspect a broken wire first .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
