Hi all,
Looks like the power problems i am having are related to the auto box!!!
Have changed the oil and the truck pulls alot better now but I have noticed if I have the truck on a gradient (not very big) and select Reverse or drive the gearbox will not hold the truck stationary as it should!! It seems to me that the box is slipping.
Is this a correct? and is there any way of adjusting this? or is the torque converter knackered??
In the australian haynes manual it says check the 'throttle valve cable' am I correct in saying this is the cable directly connected to the throttle cable???
And one last question I am persuming that the raiditor at the bottom of the engine with the fan on top is an oil intercoller??
Is this correct?
Any help would be great as I want to fix the truck this week!!!!
Jason
Is this correct?
Jason
