Won't Start
  • Won't Start
    Just finished doing some work on my 91 surf 2.4 td SSRX.
    Fitted new wiper arms. Then greased prop shaft. Now won't start. Engine turns over but won't fire up. Put into neutral using red button so I could wheel it from underneath to line up grease nipples. Anyone know of any cut offs that may cause this. Not had any problems in the past.
    Have you tried it in Park ??
      Problem solved
      Stripped console around gear leaver. A little bit of lube into the switch and now it starts and yes I had tried it in park!
        Originally posted by Rich Wildsmith
        Problem solved
        Aint it a bugger when you switch off when its in gear & it wont start weve all done that one. Glad u sorted it out.
