Interior lights
  • Interior lights
    Help needed ! one of our front interior light bulbs has blown (the one's by the rear view mirror ) now call me stupid if you want, but i cannot see how you get the cover off ? . Also on a slightly different note , is a front A bar difficult to fit ? any advice welcome . cheers- Nosher
    The cover is just clipped over the base plate which is screwed to the roof. Best to get a wide bladed stubby screw driver and lever it off from windscreen side. Should just pop off. You can also access the rear view mirror nut from there and tighten it if is loose (common problem).
      Thanks for the info, i will change the bulb tomorrow.
      All the best, Nosher
