i stripped my smurf's radiator to give it a good going over, and noticed a pipe that is hanging about doing nowt, from the under slung air con rad there are two fans atop of it and from each of these there is a pipe leading from the centre of each into a y connector then going up the inner wing, this is where mine ends my queiry is where should it go from there, the pipe is the type you would find on a screen wash feed
john
john
disco now gone aswell
