Hi
I had a problem with my 1993 2.4td auto. After having the diesel timing re adjusted and a new timing belt fitted, the loud knocking noise problem was solved.
However, I have now noticed that when I am driving gently without any turbo boost the speedo reaches 70 mph without any hassle, as soon as you try to floor the peddle, after 40 mph or engaging top gear, the car looses power the check engine light comes on.
I have carried out a diagnostic on the ecu and I am getting a code 12 timer control valve. There is no smoke or unusual noises, the car had recently had a full service.
Any ideas
help please.
Any ideas
help please.
