I have a 1992 ssr-x, LN130 frame, 2lt-e ediesel engine. I want to make some changes to have my electric fan cut in even if the vehicle is switched off. I notice the temperature could rise quite high when I switch off after a hard run. If I run the electric fan which I can trigger from within the vehicle, the temp. drops immediately.
I want to know if the electrics of the fan is in any way connected to the ECU?
If not then it would be fairly simple for me to wire the relay to trigger even if the ignition is off. An EWD of this circuit or any info. appreciated.
Robin
Robin
