Hi all,
I'm new to the forum and have question:
A friend of mine has recently bought a Surf SSR, it is an L plate diesel auto.
He took it for it's MOT and the tester carried out the test, the engine has now developed a serious knocking.
I haven't actually heard the knock myself, but it is apparently a constant knock, regardless of engine speed/load which I think rules out any bottom end problems.
My thoughts are that either a valve has broken or some other valve train problem or that the belt has jumped a tooth and the noise is diesel knock.
I don't know if the noise is coming from all 4 cylinders or just one as I haven't heard it running. Can anyone give any pointers for common problems on these engines (2L-TE)
Also, is the head from a 2L compatible with the 2L-TE as he has a very sound 2L.
