Hi, This is my first mailing so please acceot my apologies for launching straight in with my own problem.
I'm totaly stumped with what's going on with my 1990 2.4TD manual Surf and am posting this in the hope that someone might have seen something similar. The problem is that when the engine is up to temperature (showing a normal reading on the temp guage) the expansion bottle fills all the way up and then overflows - I mean really pours coolant out of the breather pipe all over the road - 1.5 - 2 litres seems typical.
This has been going on for a while. I though I'd solved the problem when I changed the thermostat but the problem is back, and may in fact never have gone - I tried another new thermostat (genuie Toyota) and have changed the rad cap (spring pressure 88kPa) but its still happening.
The water pump was changed about 6 months ago after it failed and the coolant was really well flushed at that time. I keep a 30-50% antifreeze/water mix in the loop.
Now, the weird thing about what is happing is that the coolant only seems to overflow when I stop the vehicle or let it idle when the engine is hot. The fan is spinning OK I think. What comes out of the breather pipe from just below the rad cap seems to be a mixture of coolant and air 'spitting' from the pipe. There does not seem to be oil in the coolant and the exhaust is clear of smoke/steam.
I've got a bad feeling.........can anyone offer any advice?
