2.4 rad removal
  • 2.4 rad removal
    Does anyone know the best way of removing the rad from 2.4 1992 especially with the air con rad in the way under the engine
    Any links etc
    You can do it all from the top, apart from one bolt in the middle at the bottem that holds the bottem half of the shroud on. (but check first, often they are left off.)
    You need to undo the aircon rad mounts, and pull it down enough to get to the above mentioned bolts, drain the rad while your there. Then the rest is from the top. Remove the top hose, undo the 4 bolts holding the shroud on, seperate the two halves of the shroud, (this is to get it past the fan) remove the shroud. Then you can get to the bottem hose and undo it. then undo the ATF cooler pipes and plug them with drill bits to stop the fluid leaking out. Then you can unbolt the rad and pull it out.
      Cheers tony just took it out today easy when you know how.
