Hi all
Advice needed on selectable 4WD
Can engage 4WD from the button on selector stick, although it is making a rumbling from front end, pulls to left (but drives OK in 2WD) and feels decidedly more slugish than in 2WD. Problem is it won't disengage until vehicle stops or turns sharp corner. I'm also concerned at the rumbling and pulling with 4WD engaged...could it be a wheel bearing, wheel hub or CV joint??
Anyone had similar?
Ta
Scuddy
Anyone had similar?
Ta
Scuddy
Just seen your post count so I guess you already know.
. Is there any way to check, or do any preventative maintenance that can help - greasing up at certain points on the front driveshafts, hubs, diff???
