Just picked up my 1992 2.4 surf from the docks need to do some work on the cooling system to help prevent the dreaded cracked head !! I was going to drain rad off to flush out the system but found another rad under the engine when i took the cover off I presume this is for the oil but do you have to remove this just to drain the rad and is it advisable to take the rad out to get it flow checked for blockages before i go any further
rad removal
The radiator under the engine is for the air conditioning. There is no need to remove this to drain the (water) rad - you can get at the drain cock from underneath the truck although it's a bit of a squeeze if you've got big hands- it's at the bottom passenger side of the rad.
Roger
Originally posted by GamedawnThe radiator under the engine is for the air conditioning. There is no need to remove this to drain the (water) rad - you can get at the drain cock from underneath the truck although it's a bit of a squeeze if you've got big hands- it's at the bottom passenger side of the rad.
Cheers Roger would you get the rad checked or just flush it
Originally posted by heyes5034Cheers Roger would you get the rad checked or just flush it
Pete
