on another note my hi lux has a turbo timer fitted which I don't use because I don't know what it is anyone know....seems to keep engine running for period after turning car off !!!why????should I be using it????h reg jap import auto 2.4
turbo timer
Originally posted by bowwowon another note my hi lux has a turbo timer fitted which I don't use because I don't know what it is anyone know....seems to keep engine running for period after turning car off !!!why????should I be using it????h reg jap import auto 2.4CHEERS JOHN................
you dont really need it, if driving at high rpm on turbo on the motorway for instance then by time you have got off the motorway a short time you will be ok - or just let the car idle a bit before turning off.Tim
Originally posted by dirtydogyou dont really need it, if driving at high rpm on turbo on the motorway for instance then by time you have got off the motorway a short time you will be ok - or just let the car idle a bit before turning off.
Or, if like me, you have to drive about 900 feet up a hill to get to your drive.
Turbo Timer
Originally posted by flounderThe turbo timer allows the turbo to cool down after constant use. All that hot oil in it after long journies needs to cool down, so setting the Turbo timer allows the engine to idle and cool the turbo down.
