Hi all
sorry to trouble you, but can anyone advise. my 1993 2.4 ssr-x (purchased March 2004) has always run with the temperature just below half-but recently it has sometimes risen to halfway between half and the bottom of the red. the fan kicks in and reduces it, but it can then keep moving up and down-it hasn't yet got anywhere near the red itself. have checked coolant and radiator is full. have checked overflow tank when hot, and none apppears to be coming from radiator cap.cant see any obvious leaks. on cold startup, no dicernable problems with white smoke. could it be the dreaded "head"
any suggestions please.
many thanks, shaun
many thanks, shaun
When the engine is cold, start the thing up and take the rad cap off, if you get wet feet, start looking for Stevo on this site, if the water stays in, then check the thermostat.
Back in the world of Surfdom
