Can anyone shed some light on a fuse problem..I noticed about a 32nd of a inch crack in the 80amp glowplug fuse
so proceded to get it replaced but had not have any problems to speak of regarding starting.. getting the fuse out was tricky but when i replaced it with a new one..
and started up a sort of dash board panel light surge and then all seemed as normal.
ok.. but thinking this was odd i had a look at the new fuse and low and behold it had a break in it.. so in fact i was back to square 1
but its running ok starts ok..any suggestions..may the fuse be with you.. Shiny
Nil Illigitimi Carborundum
