cv joint boot
  • cv joint boot
    Hi, I have just bought a cvjoint boot ( I think that's what it's called ? ) the rubber bit from the front wheel is splashing oil / grease. Can anyone give me an idea how to fix it ? please
    you need to take the said drive shaft off to replace the boot but while you have that shaft off it makes sense to replace both boots on that shaft
    do a search sure you will find somet that will help you!!!!!!!!!
    think its been covered a few times
    good luck
    CHEERS JOHN................
