Not Overheating but...........on a couple of occasions, after climbing a long hill, I have switched off the ignition. On switching the ignition back on, just to open a window and not starting the engine, the electric fan in front of the rad kicks in. None of the cappilliary fins are damaged on the rad and all are clear of mud etc.
The fan sensor is oviously detecting that the engine is too hot, although the temp guage on the dash shows normal, therefore it is worrying that the fan won't operate until it gets an electrical feed via the ignition switch. Has anyone else noticed this?
The only place I can see any bent fins are on the ATX cooling portion of the rad. There is a 4" square area of fins, on the far left hand side, that are bent over and closed off. I am wondering if the heat being sensed is being transferred from the ATX cooler to the engine cooling system.
I am going to carefully straighten the bent fins to see if there is an improvement. If not I am thinking of wiring the fan so that it has a constant feed, via the sensor, so that it is independant of the ignition switch. That way it will run on for a minute or two after the engine has been stopped.
Opinions, please, from the more learned.
