Ive had my surf for about a month and everything has been good so far. Last night I was driving it on the motorway and it started to heat up, so i put the heater on full blast in the car and the temp dropped nearer normal. it fluctuated all the way to my destination, but never into the red. when i arrived it was just below the red and i switched off allowed to cool then checked water level. it was way down and took nearly 2 litres to fill via the rad cap filler.
I checked the oil and its smooth black with no sign of milkyness or foam.
could this be a simple coolant leak? Im quite worried about having let it get so hot, as I said before it never went into the red, but if the head is prone to crack is there anything I can do to find either a slow coolant leak or a more serious problem? It is still covered by the warranty from the garage I bought it from, but I would rather source the problem first before I have to call them if its more than just a leaky cap or hose. Plus, what coolant/anti rust stuff should I be putting into the rad to replace my simple tap water from a bottle?
any advice greatly appreciated.
she's no angel
