Originally posted by Tallyman
big problem i need help
Originally posted by SilversurferMy local Toyota parts dept reckon they can get anything required for a Surf - the most common items (service items etc) are held in this country anything else can be obtained within days - as already said, you have rights, don't let them fob you off. If they do offer you a write-off payment - again you have a right to market value and nothing holds it's value like a Surf, make sure you have plenty of dealer adverts as evidence of value and insist on that value. And should they write it off you normally have first option to buy it back where - as you now know - parts are available and there are lots of dedicated Surfers on this Forum who will gladly help you out.Good Luck and Nil Illigitimi Carborundum (Don't Let the B*****ds Grind You Down)taekwondododo
There is a Surf in a breakers yard in Sittingbourne in Kent on Gas Road.
I think they are called Unitied Salvage, though I'm sure they'd be easy to find on the web.
It has had an underbonnet fire, but from the doors back seems ok.
No parcel shelf though!
Rob.Thedo know how to build a damn good 4x4!
