Surf Manual
  • Surf Manual
    Can Anybody help me out I am after a manual for a Hi- Lux Surf, H.reg 1990/91 I have had this surf for 9 mounths and I have only had it on the road for 6 weeks as the crank broke so I had to get another engine which was very costly. Now the engine is done 2 weeks on and the head cracked, now that has been done I can't get the turbo to work and it keeps over heating, and I am getting to the stage where I am starting to over heat also. If anyone can help me out I'd be very gratefuf. Many thanks
    The Fox
    Attached are the vacuum hoses check these Ref TURBO.
      The Fox
      Check on Amazon - Hayes do a maual and there is a Max Ellery one too Max Ellery
      haynes
      Linda
      www.4x4toys.co.uk
        Hi Marky, many thanks for the diagram I will be checking it real soon (when it stops raining). Thanks for spending the time in trying to help me out,
        Rockin' Regards
        Nigel.
          Manual
          haynes
          Hi Linda,
          I have tried Haynes but they don't do a manual for a Hi - Lux Surf turbot diesel. I have seen one on the 2.4 Austrialian 4 Runner but again it's not for the turbo. I will check out Max Ellery, Thanks V much
          Rockin Regards
          Nigel
            On Manuals and Owners Handbooks
            re: Manuals for hilux surf turbo 3.0
            Neither of these manuals quoted on amazon seem to mention turbo, as I could see..... nobodys put in a write up either.
            Am I better looking up a plain hi-lux for the "stuff underneath"?
            (bit of a technobaby I am afraid)
            BTW readers, you see the Onwers Handbooks (even being flogged on Amazon) watch out for the year numbering, they mean 89 - 95 (2nd Gen) not 89-93 - caused severe buggering about with emails and refunds for me last year.
            Worth it though to find out "dont use 4wd on tarmac", and "stick it in 4wd mode now and again to keep it all working".
            So, if you have a 2nd Gen Surf dated 94/95 (that is EARLY 95, not a 3rd Gen) then the wrongly worded "Surf 89-93 Owners Manual" is the one for you. How we explain that when we come to sell the car is another thing.
            I like mine so much I plan to run it into the ground...
              The max ellery and haynes manuals are fine for everything apart from the engine, Roughtrax sell a genuine Toyota engine manual for the 1KZ-T, which is as close as you'll get to your 1KZ-T/E, its only short of the EGR and electronically controlled fuel pump which the UK 4Runners don't have.
                I have this manual:
                http://homepage.ntlworld.com/bolloxx/1KZ-TE.rar
                It's off a later model but maybe it will help in some way.
                [CENTER][img]http://www.danasoft.com/sig/bolloxx.j
                  This manual can also be seen on-line at;
                  http://www.showmesome.info/hilux/info/manuals/1KZ-TE/
                  and is available for download on a PDF from;
                  http://surf.mactherapy.com/
                  and if you are interested you can download the Toyota EPC manual from;
                  http://www.showmesome.info/hilux/inf...ks.htm#manuals
                  Regards
                  Mike
                  [FONT=Comic Sans MS]"Inveniam viam aut faciam" - S
                    Forgive the ignorance, but...
                    Originally posted by bolloxx
                    I have this manual:
                    what's a .RAR file and how do you open it?
                    Cheers for making it available by the way.
                    Rob
                    Constantly Striving to Attain Lower Standards
                      Rob
                      its like a .zip file,
                      i think the software is from www.rarsoft.com - thats the one I have always used anyway.
                      Tim
                        .RAR file
                        A .rar file is a compressed file, not dissimilar to a zip file.
                        To open it you need a program called WinRar which can be downloaded from here http://tinyurl.com/aplny
                        [SIZE=2][COLOR=White]You can't have everything. Where would you put it?[/COLOR][/SIZE]
                          Surf Manual
                          The Fox
                          Look On Web Site
                          www.japanese4x4spares.co.uk/toy-hilux-surf
                            try ebay i got mine from a guy called steve sutton aka manual man just type in the name then you may get it up he does all sorts of manuals
                            type steve sutton or manual man
                            taekwondododo
                              sorry just looked him up its sutton_steve
                              taekwondododo
