Hi,this is my first thread and i need a bit of help.Just noticed a leak under the engine (passenger side)that drips down from the bash plate quite badly when the engine is hot but virtually stops as the engine cools down.It's red/brown, feels like a very fine oil and smells faintly of fish.It's late, it's dark and i'm worried.Will have to look at it in the morning.Any replies welcome,thanks.
fluid leak help please
Could be power steering fluid or even coolant. Check both reservoir levelsOriginally posted by monty146Hi,this is my first thread and i need a bit of help.Just noticed a leak under the engine (passenger side)that drips down from the bash plate quite badly when the engine is hot but virtually stops as the engine cools down.It's red/brown, feels like a very fine oil and smells faintly of fish.It's late, it's dark and i'm worried.Will have to look at it in the morning.Any replies welcome,thanks.
Checked it first thing this morning,a bit daylight always helps! It was coolant, coming from the top hose into the radiator.It's not damaged but noticed that the clip that holds it in place wasn't in the original position,so put it back where it should be and all looks well.A local garage has just changed the timing belt for me is it possible they moved it perhaps to get access to the belt? PANIC OVER !!Originally posted by justaminCould be power steering fluid or even coolant. Check both reservoir levels
