What does the E C T button do?
Well silver, two things, should I drive with the ECT on or off?Originally posted by SilversurferIt raises the speed at which the up changes are made on the auto gearbox for better acceleration
Cant decide if I want to be a boy racer again
And I cant be bothered to translate your doobery, so you tell me your translation and I will tell you mine
Back in the world of Surfdom
Drive with the ECT on if you don't mind paying around £4 a gallon for diesel - you will use a good bit more using the ECT.Originally posted by DjandcoWell silver, two things, should I drive with the ECT on or off?
The doobery roughly translated means 'Don't let the Ba***rds grind you down
There - Iv'e told you mine - now you tell me yours !!
its on my busymess cards, couldn't think of anything interesting to put on it, so I opted for a rough transltion of,
Can't see it from my house
Although it starts off with impossible to see it, cos the latins didn't use the work "cant"
They would never have lasted in todays sociaty!
Shows why the latins are extinct!!
Next question has got to be - what business are you in - your profile say's Miracle Worker - do you do contract work by any chance ?Originally posted by Djandcoits on my busymess cards, couldn't think of anything interesting to put on it, so I opted for a rough transltion of,
I used to work in research and development for the auto door industry.Originally posted by SilversurferNext question has got to be - what business are you in - your profile say's Miracle Worker - do you do contract work by any chance ?
Then I thought, whats £26k a year when you can be self unemployed and do what you want!
So now I do everything from gate/barrier automation to one off lighting intallations.
Anything that is different and not the norm.
My mates house is living proof!
It's to bypass the ignition interlock on the gear change. If you hold it down you can move the gear lever out of park without having to have the ignition on.Originally posted by BUSHWHACKER View PostWhat is the red button next to the gear lever for?
I have a 2nd Gen 3ltr and can run 50% veg in the summer without problem. Fitted a DieselVeg two tank conversion about 5yrs ago and can run 100% veg. Never had any problems as long as you make sure that you start it on the diesel tank and let the engine fully warm up before switching to veg. There is no noticeable difference in performance between diesel and veg, apart from the exhaust smells like a chip shop.Originally posted by BUSHWHACKER View PostWell I never!
Can I run my truck on veg oil?
DO A SEARCH for ECT
Nil Illigitimi Carborundum
