I was convinced the tappets needed adjusting on my surf as there's a ticking/tapping sound in line with the revs thats obvious at start and almost dissapears when fully warmed up and has got slowly louder for last 4 months or so,
I've ordered a new rocker gasket, read the relevant pages in Haynes and thought I would look on here before tackling on saturday but I've just done alot of searching and am now confused.
Haynes says I have tappets I can adjust but theres alot of talk of changing shims and loosening the cam belt to get to them and special tools on here, that sounds a bit too complicated for my mechanical skills (it took me over 2 days to change the cam belt, don't really want to get that indepth for another 100k,km), others also say it can't be the shims because they won't wear down. I've also read it could be injectors, are these possible to check by an amateur mechanic. Could I have put the belt on slightly wrong (although it's done <15,000km since), there is a bit of smoke when accelerating but not whilst cruising (needed some injector cleaner to pass MOT), Any ideas welcomed (especially if they're easy)
