I tried to drain my radiator but failed at step 1. I removed the bash plate only to discover a second radiator almost parallel to the ground. This masked the main radiator so I couldnt find a drain tap. My questions are these, and I apologise if its in the FAQ or anything.
1. What is this radiator? Guru Simon thinks it might be an optional "towing pack" where you have an additional transmission oil cooling radiator.
2. How do I drain the radiator and block when this radiator is in place and I cant get at anything.
It is a 1992 2.4 BTW
