More bad news?
Had complete new engine in January, so hoping that would be the end of my worries. But over last couple weeks its started smoking (Black) whilst under load also quite a large cloud (grey) on start up. Before Morr jumps in I have trawled posts and have just done the EGR Mod. Also had alot of oil in the air intake pipes so these have been cleaned and the breather pipe blanked off and the rocker cover pipe conected to a catch bottle. There was also an oil leak from top of engine which I first thought was coming from the breather pipe and dripping down. However it is actually comming from the Inlet manifold! There shouldn't be any oil in there surely?
What I am hoping is that its the crap from pre egr mod/ breather contamination leaking out, how ever if oils leaking out then its obviosly not air tight either.
Just hoping its not turbo seals couldn't feel any play in the impeller.
Any ideas chaps?
Steve
Any ideas chaps?
Steve
Turbo seals. Are you sure the leak isn't from the rocker cover gasket, this where motor normally leak, also Surfs sometime get a small oil leak between the head and block. but it does no harm.
