oops think the grease monkey has put in just over 7lts of oil in my engine, it now reads just over full on the dip stick by a few millimeters. will this do any damage or do you rekon i can get away with it?????
oops too much oil
Originally posted by mr dogoops think the grease monkey has put in just over 7lts of oil in my engine, it now reads just over full on the dip stick by a few millimeters. will this do any damage or do you rekon i can get away with it?????
Otherwise, it should ideally have some drained to bring it into the correct range as the maximum limit it there for good reason, too much oil can cause oil seals to leak and other internal problems.Maurice
Might leak a bit if overfilled. Best drain a bit out if possible.
Nevillef
