Hi All, I have a Lovely 1993 K Reg blue 2.4 auto diesel ssrx, which I have had no problems with untill!!! I put it into a garage to have the timing belt done.
To cut a long story short the belt was changed they also changed the water pump as they said it was leaking, and now I have sludge in my coolent and the heater blows cold air for a good while and air locks have appeared in my cooling systems plus every now and then I get a bit of a steamy exhaust. All of this never used to happen, but I need to get it fixed, My Dad is no mechanic and recons it's the head gasket and I know the 2.4 are prone to this, so knew one day it might happen. I need some help/advice to confirm what I've said above does sound like it's the headgasket? I live in South Wales and if anyone else lives this way and had the same problem who did you take it to or can anyone recommend a specialist for fixing this. And how much of a dent is it going to make in my wallent as i have no Idea!!
I would greatly appreciate any help as my SURF is now off the road as I don't want to warp the head itself by over heating it. HELP HELP HELP
Also is this likey to happen again once it's been fixed ????
Many Thanks Matt SURFLESS
