Hello I have just joined the club (shiny) and no longer feel in the dark or on my own.
I hope someone could shed some light on 3 problems that I have with a Surf 1990 2.4 turbo diesel
No 1 when I start cold there is no turbo light and when it gets to a certain temp it comes on, and produces a surge then when it’s fully heated it goes off permanently.. Sometimes it comes on intermittent at random times, their seems to be no problem in power but I do notice when it comes on a mild surge. No pipes are disconnected I have a turbo timer but this is switched off and there is no difference if on. The battery has been disconnected several times, does this do something?
No2 it has a creaking sound when I turn sharp left or right especially if I go up a slight mound either side at the front.
No 3 it has a oil leak (don't they all) I have been told it’s the seal between gear box and engine but I am not convinced as it seems to come from a area above the engine block. I have had a new fuel pump gasket fitted so it definitely is oil underneath, it’s hard to tell where it’s coming from. will a oil seal liquid in a tin from a garage help?
Thanks everyone if you could help me I would be very Shiny
Pete
Pete
