Hi all.
Just got back from a trip to the tip today, turned into the gates and half way through the turn , the power steering packed in.No warning, just bang it stopped working Lucky I was only going slow so managed not to take the gate post out. they don't half go heavy when it packs in. I managed to get it in and park up , the noise when I tried to turn the wheel was terrible, it screamed on both locks. it sounded like metal on metal as though something had stripped or sheared and was still trying to turn. It sounded expensive.
Sunday so no garage open, Decided to have a quick check on the basics myslelf. Didn't hold out much hope as it sounded serious stuff.
Found 50 mm free play in the drive belt. tightend up all OK. I just couldn't beleive that a slack belt could make that sort of noise, and the fact that I got no warning. I'm assuming the pump must have slackened off and suddenly slipped when I put load on it. So its a good thing to do a basic check before you call in the Top Guns.
Rgards all ......Ron
brrrrrrrrrrrrr!
