Hello All,... after reading many threads and visiting a couple of mechanics,  I am hopeful that you can help me eliminate whether I need a new clutch and clutch pressure plate or simply a replacement of the Master and Slave cylinders. I have bleed the system, to no avail,…
The initial symptoms were sticking clutch pedal on release, but now it is still sticking, but in first and reverse gear even with the peddle down (clutch disengaged) it still has drive going to the wheels as if engaged (car creeps forward). I have had a quote of 875 pounds for the replacement of the clutch and pressure plate from Jem, but am not so happy to spend so much if I am unconvinced that the pressure plate has started to disintegrate as they think might be the case. Has anyone had a pressure plate disintegrate or is there an adjustment that I might have missed in the forums for the clutch to overcome this?
I have looked at the firewall and eliminated this, there seems to be no cracks in the peddle box, etc that might cause this.
It is a 1991 J reg (not facelift but still 2nd Generation)
I know there is a wealth of info out there and all thoughts would be much appreciated. I am at presently unemployed (heaps of time) with a average mechanical knowledge, tools and the beloved Haynes manual. If it is the pressure plate I am contemplating doing the job myself, any thoughts re this?
Thanks very much, Happy Surfing!
 Clutch pressure plate disintegrating?
