Finally got the head off today, and I can't see any obvious cracks and no massive rusty leaks or anything. However, if you could just take a quick look at these photos of the top of the block and let me know if anything looks bad - I'm not really sure how to spot the signs of a gasket leak or crack.
The cylinder bores are completely smooth - no scouring or anything that can be detected by running you fingernail around. The only thing is the carbon deposits at the top cm or so of each cylinder - is this normal? Presumably this is where the piston rings don't clean the bore. The front 3 are smooth deposits but the back cylinder's deposits are a bit lumpy and rough. What does that mean?
Finally, the flash on the camera really makes everything look rusty - in real life it looks a lot less orange!!! Image 6 looks most like the real thing (ie. mostly grey).
thanks
James
http://www.jameskett.dsl.pipex.com/img1.JPG
http://www.jameskett.dsl.pipex.com/img2.JPG
http://www.jameskett.dsl.pipex.com/img3.JPG
http://www.jameskett.dsl.pipex.com/img4.JPG
http://www.jameskett.dsl.pipex.com/img5.JPG
http://www.jameskett.dsl.pipex.com/img6.JPG
http://www.jameskett.dsl.pipex.com/img7.JPG
thanks
James
Nil Illigitimi Carborundum
