Right, I have a bit of a strange one, my rear window is opening by its self, it wont close unless I take the connector and reverse the connection/polarity at the motor on the tail gate, the motor would seem to be constantly trying to work as it gets very hot. If I disconnect the switch in the front which operates the window it still happens, is there a relay for this?? I have checked the micro switch on the key barrel and all is ok there. I have seen in other threads there is a control box but where a bout’s, I have been unable to find it Checked the rear quarter panel and its not in there, I’ve checked the wiring loom as far as I can and can see no damage.cheers
