transmission
  • transmission
    someone please give me info as to the location of the number 1 solenoid in the automatic transmission on the 1993 toyota hilux surf.
    joker
    Inside the gearbox????
    Seriously though you'll have to come up with the transmission code, found on the plate in the engine bay. I spoke to a fella tonite who knows nothing about it either but he does have a manual with details covering the A343F auto box.
    There you have it, let us know.
      transmission
      the transmission code in the engine bay is A343F. just what he has i suppose is what i need. he can email the info to me at [email protected]
      please send to me as soon as possible cause i'm anxious to get this thing sorted out as i was having this problem for a while now.
        Transmission
        Hi Joker
        Iv'e Emailed you with the info on Toyota Auto Transmissions - hope it helps
        (Too big to post to forum 570Kb)
        Silversurfer
        Nil Illigitimi Carborundum
          Right, here goes. This info is from a Landcruiser Colorado manual which had a 1kzte engine and an A343F auto box.
          On the passenger side of the box (I'm talking right hand drive, call it drivers side for left hand drive) there are the following items, starting from the front of the box going towards the rear....
          1st item: Neutral start switch (its a plug with 5 or 6 wires?)
          2nd item: Lockup solenoid valve
          3rd item: No.2 solenoid valve
          4th item: No.1 solenoid valve
          5th item: Speed sensor (no.2 speed sensor, near transfer case)
          6th item: Speed sensor No.1 (on transfer case)
          The above was taken from a diagram, hope it helps.
