When I accelerate hard over 3000 rpm the turbo light goes out and the red engine management light comes on although there seems to be no apparent loss in power. Anybody got any ideas !!
Engine Management Light 2.4td
if the check code is a 12 its timer control valve have you got a loud diesel knock and maybe a bit more smoke than normal does it turn off smoothley? i had this and found it was the timer control valve was shot check the resistance of it, i think it should be between 10 and 14 ohms mine was about 26 so threw it in the bin and replaced it tricky to do with pump in place but can be done with loads of swearing and grazed knucklesif aint gone pop yet chances are it will
