Hello everyone, further to identifying the problem with my auto box as a solenoid, I decided to confirm this by running the diagnostic on te1 and e1. Initially I tried it and got a code 2 and a code 12 on the engine fault light but nothing on the overdrive??? Took the fuse out of the ecd for a minute just to check if i had the problem.
Tried it again and now the engine check light is not showing and code (thought it should give a code 1 ia all was ok). Is starts without any problem and sounds sweet but just worried it isnt showing a code.
The overdrive light still isnt showing any code either though. Is their a different way for testing the transmission or should it still use te1 and e1???
Any help greatly appreciated
