Hello everyone,
finally got around to starting the removal of the head on my H reg Hilux Surf 2.4TD (after the little overheating and water boiling problem) and I'm following the instructions from this site, but I've had to bypass the draining the cooland system step as the bottom of the rad is completely hidden by another massive rad mounted almost horizontally, which we are guessing is the aircon rad?
So, how can I actually get at the main rad to drain the cooling system out? I can't see the bleed valve that's supposed to be on the bottom of the rad (there's a load of foam stuff stuck in there bewteen the two rads) and can't see the bottom hose at all due to all this extra stuff in the way.
Any ideas? I assume many Surfs have this huge second rad, but the instructions don't mention what to do with it.
Here's a picture of th front underside showing the rad -
http://www.jameskett.dsl.pipex.com/second_rad.JPG
Thanks very much
James
Thanks very much
James
I,LL GO FIRST NO PROB
LOL
