Hi all,
I recently bought a surf, 3 months ago, I did the usual things after buying, changing filters, oils, etc...
However, my car overheated during a trip and the cylinder head went. I had a hard time finding a head but finally did and put it on. It worked normally for a while but as soon as I took another trip it started to overheat again, I stopped the car and let it cool down, I discovered that it was running out of water. When the mechanic had a look at the car he could not find any water leaks. Someone then told me to check the radiator cap which I then changed for a new one, eversince I have had no water loss, magic I guess. and the thermostat was also removed. Now, after all these problems my 4WD light on the dashboard will not light anymore when I engage 4WD but the 4WD works, where can I check that?
