Hi All,
Just a quick one - if you will pardon the expression !!
The Surf normally starts with half a turn of the key - but after leaving her on the drive for a couple of days takes a little longer ?
Seems like the fuel is draining back from the pump over time - no leaks visible - once started shes fine again - just seems like if its left it has to drag the fuel up again -any clues as to what to check for would be greatly appreciated !
Cheers,
Kim
Cheers,
Kim
