OIl leak that doesnt seem to be above the starter by much if at all Tightened what I can get at 326k's Had the rocker cover off recently and only used sealant on re-install but can get my hand down the back a bit and come up with no oil on my fingers Have brakekleened the area and wiped as much as I can Next step is to run the motor and see what happens Its been sitting on axle stands for a week and no drops have fallen on the floor HELLP I have just finished running the temperature up to normal and noticed oil coming out of a sponge like fabric that is sat between the rear of the sump and the front of the gearbox One can push this and oil comes out from it I ran the motor for 15 minutes and noticed the oil pool which ran down the sump to the drain plug itself
OIl leak 94 Engine TKZ -TE Model KD-KZN130 Rear motor around starter passengers side
