For those of us that have ever used a Haynes Manual in attempting home
maintenance of a car.
For those who have not used a Haynes Manual, these are the books aimed at
car-owners who want to fix their own cars and which keep qualified mechanics
in paid employment putting things right afterwards.
They are chock full of photos, diagrams and step-by-step instructions which
are obvious if you are a fully qualified motor mechanic, but which are
frighteningly sparse on detail for the average Joe in the street who wants
to change a set of spark plugs on a 1981 VW Polo ....
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips (adjustable wrench) then beat repeatedly
with hammer anticlockwise. You do know which way is anticlockwise, don't
you?
Haynes: Should remove easily.
Translation: Will be corroded into place ... clamp with adjustable wrench
then beat repeatedly with a hammer.
Haynes: This is a snug fit.
Translation: You will skin your knuckles! ... Clamp with adjustable wrench
then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Not a hope in hell matey! ... Clamp with adjustable wrench then
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now you
are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Ease ...
Translation: Apply superhuman strength to ...
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to
dig out the bayonet part and remaining glass shards.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing then re-check the manual because what you are doing now cannot
be considered "lightly".
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating (simple).
Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, ikkle number... but you also thought that the wiring diagram was a map
of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating (intermediate).
Translation: Make sure you won't need your car for a couple of days and that
your AA cover includes Home Start.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating (expert).
Translation: OK - but don't expect us to ride it afterwards!!!
Translation #2: Don't ever carry your loved ones in it again and don't
mention it to your insurance company.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahaha hahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search for it in the dark corner of the
garage whilst muttering "******" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking
at, then declare in a loud knowing voice to your wife "Yep, as I thought,
it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking feeling in the pit of your stomach has subsided, you can
start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift or pin-punch...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Translation #2: Heat up until glowing red, if it still doesn't come undone
use a hacksaw.
Translation: Unless you have a blast furnace, don't bother. Clamp with
adjustable wrench then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to
do!
Haynes: Remove oil filter using an oil filter chain wrench or length of
bicycle chain.
Translation: Stick a screwdriver through it and beat handle repeatedly with
a hammer.
Haynes: Replace old gasket with a new one.
Translation: I know I've got a tube of Krazy Glue around here somewhere.
Haynes: Grease well before refitting.
Translation: Spend an hour searching for your tub of grease before chancing
upon a bottle of washing-up liquid (dish soap). Wipe some congealed washing
up liquid from the dispenser nozzle and use that since it's got a similar
texture and will probably get you to Halfords to buy some Castrol grease.
Haynes: See illustration for details
Translation: None of the illustrations notes will match the pictured
exploded, numbered parts. The unit illustrated is from a previous or variant
model. The actual location of the unit is never given. The best one I
encountered was how to change a brake sensor in a Ford Fiesta Popular Plus.
The photo showing the location of the unit failed to mention the crucial
detail of whether the item was located in the engine compartment or inside
the car ..... and the helpful photo of what the thing looked like didn't
give the reader any clues!
you?
Haynes: Pry...
Haynes: Undo...
Haynes: Ease ...
Haynes: Lightly...
Haynes: Compress...
Haynes: Inspect...
use a hacksaw.
Haynes: Index
do!
bicycle chain.
a hammer.
