At last its done.....!
  • At last its done.....!
    Finally did the jobs I have threatened to do since I got my Surf.
    Flushed the cooling system, changed the oil and filters.
    Well, the coolant was a dirty greyish reddish brownish liquid that looked like it could have been in there for years.
    Anyway I flushed it through with the stat out until the water ran clean. Ive got to admit though despite the state of the coolant what I could see of the inside of the rad, hoses and engine water galleries it was pretty damn clean! Most UK market cars I have had the pleasure of flushing have all had a dirty rusty colour on the inside.
    The air filter is fairly black and it was supposed to have had a full service when it arrived here at the end of July including antifreeze!
    Anyway it is all done now and I can rest assured that it is. However, I have a worrying rattling /knocking noise when the engine reaches around 2k revs I'd swear it was not there before the oil change. I was told the oil I used was fine so now i'm not sure what to do.
    As I mentioned when I first joined this merry band I have only had the truck since middle of September. Since then I have had loads of helpful advice from users of this forum and for that I thank you all.
    Ian
    One day my paranoia will go away!
    Check your air filter some people reported that their new air filter rattles in the can when under revs.
    I think they got them from Milners but I use their filters - no problem
    Geoff
      Well I tried the air filter but the noise was still there until the engine warmed up.
      Maybe I just needed to get the new oil circulated but I'm unsure if the oil I used is really up to the job. Or maybe the old oil had some kind of additive in it?
      Ian
        ian, the red stuff you flushed out of your rad was VIMTO
          Are you sure it wasn't Aftershock?
          Powered by ????
