Can Shell Helix 10w40 engine oil be used in a Surf 3.0TD?Cheers.
Shell helix
If you get the diesel stuff, yeah!
http://www.shell.com/home/Framework?...s_ga_0110.html
Originally posted by RobDCan Shell Helix 10w40 engine oil be used in a Surf 3.0TD?Cheers.If life's an uphill struggle then downhill from now on can't be that bad?!
I got the filter oil change done at ATS(£34.99),next morning found a pool of (old) oil on driveway,which is on a steep slope(obviously spillage on inside of sump guard seeped out),then the following day noticed a fine spray of oil on drive around the overflow pipe(filled too full?)they reckon it takes 4.5 litres,is this correct for a 3rd gen?Powered by ????
Originally posted by RobDI got the filter oil change done at ATS(£34.99),next morning found a pool of (old) oil on driveway,which is on a steep slope(obviously spillage on inside of sump guard seeped out),then the following day noticed a fine spray of oil on drive around the overflow pipe(filled too full?)they reckon it takes 4.5 litres,is this correct for a 3rd gen?
