Hi All
Picked up my new surf 3.0td ssrg! Luv It! But now I have a problem!
The dealer said they would flush the rad but wheni got home and tested the dirty brown coolant It had no protection at all! So I thought i'd change it and the thermostat,do a flush with hospipe etc! put the new themos in and decided to fill up with tap water and heat up untill thermos opened and the drain when cool and refill. but after 15min of idle up running the thermos wouldn't open and the guage wasn't showing any more than a shade to the left of the middle. Thinking duff thermos i put the old one backin (It looked as If It was a new one any way, maybe they did the flush but reused the old coolant) Still the same after about 15/20mins still not hot enough to open thermos! now I'm prob paranoid about over heating so im loathe to drive It with the tap water in. I'm letting it cool for a couple of hours and going to put in toyotas forlife and see if It makes a difference. I understand that plain water has v.good cooling properties so im hoping this will solve! The heaters all blow hot air and there dosn't appear to be any airlocks.Hope some one can give me some advice as I cant drive the my new surf!!
Neil
Neil
