My surf has suffered 20 years of salty roads.  The bodywork is fine.  The chassis is solid but there is surface rust everywhere.  I have a friend who restores cars who will charge me mates rates to restore it.  I plan to have the suspension stripped off and then the underneath hydro-blasted before spraying with Yacht Primer, then stonechip paint.
1) Most suspension components need replacing. Have I missed anything obvious off this list?
2) Karma Supra - can I talk to you about your rear axle casing please?
3) Are uprated anti-roll bars available?
4) Do the wishbone arms come with bushes already fitted?
Shopping list - Gen 3, 3.0td auto.
Front droplink x2
Front lower wishbone arm x2
Front upper wishbone arm x2
Front lower wishbone arm bushing x4
Set of upper and lower arm long bolts/nuts
Lower wishbone arm camber bolt adjustment x4
Front anti-roll bar bushing x2
Front anti-roll bar clamp x2
Front disk brake back plate x2
Front coil springs x2 (+20%)
Rear coil springs x2 (+20%)
Front shock absorber x2
Rear shock absorber x2
Front shock absorber gaiter x2
Front top shock mounting with nut/bolt set x2
Rear drop link x2
Rear upper control arm x2
Rear lower trailing arm x2
Rear anti-roll bar
Rear anti-roll bar bushing x2
Diesel tank filler and breather
Rear axle bump stop x2
I have already had front discs, calipers, track rods and tie rods replaced.
Front droplink x2
Rear drop link x2
Rear anti-roll bar
