Originally posted by G1bbo
View Post
You bridge the E1 and the TE1 pins with a paperclip or similar, then turn the ingnition on and and count the flashes of the OD light.
For example 6 continuous flashes, then a little pause, then 3 continuous flashes.
Once you have the 2 digit number, enter it in here:
http://codes.rennacs.com/FaultCodes....commonRepairs=
If you got 63, then it would be solenoid n 2 needing replacing.
The 9 code for speed signal/ sensor is an ENGINE CHECK light code, when the 'check engine light' flashes 9 times.
If you got that and your OD light just keeps flashing intermttently without a pause/pattern, then your autobox is fine.
Hope that makes sense.
