Looks very nice, even the tyres are shiny (Vince would have approved) cant beat black polished up,
did you reverse the rims to get the deep dish effect? (it's what I did) looks good,
I actually washed mine today for the first time in over six months
Ha, I should have done the insides of the tyres!
Nope they are alloys, just negative offset ones... they can be a bit of a pain as I had to lift more than most to clear 33s, without rubbing on lock when loaded up.
Had the same problems with clearance, reversed rims equals more rotation curve when steering, rather than alter the torsion bars I chopped away some of the outer wing where the sills are, they still catch slightly depending on how many people are in the truck, the deep dish look does look great I think though so worth the aggro
Popeye, yup, I went the route of lifting bit more before chopping bodywork, I only trimmed the plastic arch extensions at the front..
The alignment also seems to make a pretty big difference, as the caster adjustment sweeps the lower arms forwards or backwards. mine only ever catches on the passenger side.
